A keyword search facility is present on every page of the site,
at the top-right of each screen, next to the tool bar labelled
"Search". This searches all of The Caravan Club's website.
If your search does not return any results, you will be prompted
to search again.
Getting results
- Be specific - choosing the right search terms is key to finding
the information you need and searching for a single word may not
give good results. The more information you provide, the better
your results will be.
- Remember the search engine will return pages with all your
keyword search terms on them, so there is no need to include "and"
between your terms.
- To find pages that include either of two search terms, add an
uppercase OR between the terms, as in 'holiday Yorkshire OR
Burgundy'. If you wish to find two terms, use an uppercase
AND.
- Most search engines ignore common words and characters such as
where, the, how, and other digits and letters which slow down your
search without improving the results.
- If a common word is essential to getting the results you want,
you can include it by putting a "+" sign in front of it and be sure
to include a space before the "+" sign.
- You can also conduct a phrase search, which simply means
putting quotation marks around two or more words. Common words in a
phrase search e.g., "where are you" are included in the
search.
- If you are using a word which has more than one meaning, you
can focus your search by putting a minus sign "-" in front of words
relating to the meaning you wish to avoid. When you include a
negative term in your search, be sure to include a space before the
minus sign.
