Many of our sites can now be viewed using 360º technology. To
view the 360º pictures, and to make sure everything is displayed
correctly, you will need to have Java installed on your PC.
Fortunately, most PC's have this installed as a matter of course
and so should not bother too many users. If you do experience
problems however, it can be downloaded from the link below.
Firstly you will need to visit the Java
download website, once there have a look for the 'Java
Runtime Environment (JRE)' download. Click download and then select
the relevant platform. From this point on follow the onscreen
instructions to download and install the JRE application.
To see some examples of the 360º photography and to see if your
Java installation works, click on the links below.
