Coachman VIP 575
Rob McCabe
Rob McCabe spends time with the latest iteration of a familiar model
Coachman’s en-suite end-bedroom 575 has been the Hull manufacturer’s biggest-selling layout for years. Similarly, the VIP range has been the company’s poshest single-axle range ever since it took its bow all the way back in 1988. Put the two together, add 30 new features for the 2027 model year, and the end result is… well, let’s find out.
Build quality – 90%
Coachman’s reputation for producing caravans that are extremely well screwed together is safe – from the quality of materials used to the assembly, the VIP impresses greatly, and has an aura of real class. There’s just one tiny blemish. The concertina blind that pulls across to shut off the bedroom is secured by a tiny, solitary magnet – during my time with the caravan, a gentle through-breeze was all it took to dislodge it on several occasions.
Towing – 93%
The 575 is the epitome of a perfectly balanced caravan, with all the heavy stuff – fridge, cooker and microwave – positioned right above the axle for optimum weight distribution. So, loaded sensibly, it’ll be on its best behaviour everywhere. Al-Ko ATC is, as you’d expect at this level, on hand to intervene if needed.
As we went to press, weights for this just-launched caravan had not been confirmed – we’ve used the figures for the outgoing model as a guide.
Daytime – 89%
Stylish lounge
One of the new features is strikingly apparent as you step inside: the lounge walls feature what is officially called ‘acoustic-style media wallboard’. The result is easy on the eye and gives this area its own distinct identity. It’s a peachy lounge in every regard, with premium-feeling upholstery that gives great comfort and support. There are plenty of ways for daylight to get in, imparting a pleasing light, airy ambience.
The curvy, deep front shelf is an impressive piece of design and, thanks to the neat, pull-out extension, highly practical with it. You shouldn’t need the services of the freestanding table at most mealtimes, but its bespoke locker – just by the entrance door – makes it supremely accessible if you do. The new illuminated cocktail cabinet is a nice thing, although the fixed shelves inside preclude fitting any bottles in there.
Six mains sockets are strategically placed throughout the interior, and there’s a USB-C slot on top of the nearside dresser. All six reading lamps have older-style USB-A sockets built in.
For audio, you get two little Bluetooth speakers on the underside of the front window shelf. Unfortunately, however, the sound produced is a little thin and underwhelming.
Storage options are in bountiful supply, headed up by the enormous space under the bed. Getting to it couldn’t be easier – the base glides up easily on its hydraulic support and is happy to stay there on its own while you load or unload.
Night-time – 95%
Comfortable double
Central to the 575’s ongoing success is the wonderful en-suite bedroom. The opulent transverse island bed is terrific, big bedside tables will take coffee mugs, phones etc, and the corner shelf has all the socketry you need for the TV. You can even control the Alde heating via a bedside touchscreen, complementing the one above the entrance door.
Just like up front, the dark wood contrasts beautifully with the paler highlights (including the plush, soft-touch headboard) to give a real upmarket feel. There’s just enough room to ease past the bottom of the bed when it’s fully extended – and when it’s pushed back into ‘day mode’, you could drive a veritable bus past it.
The parallel sofas in the lounge convert into a big double bed that, thanks to the substantial upholstery, is outstandingly comfortable. If it were the only bed on board, I’d be very happy with it. That said, the knee rolls on the sofa squabs are quite pronounced, so they do need to be manhandled back to front for a flat mattress.
Kitchen – 96%
L-shaped kitchen
This subtly L-shaped facility looks great (the new marble-effect work surface is especially attractive) and has real substance to go with the glamour. The integrated extractor fan lends a posh-domestic-kitchen look, as does the chunky cast-iron pan support on the dual-fuel hob. A flatbed microwave is neatly integrated on the nearside. Storage is exceptional, headed up by a brilliant slide-out cupboard with full-height racking. A pop-up extension boosts the already decent work surface, as does the thick, flush-fitting sink cover – it’s recessed, so you can still drain into the sink when it’s in situ. All very nicely done.
Washroom – 91%
On-trend black fittings in washroom
The designers have embraced an in-vogue ebony theme here – the ladder, radiator, door handles, shower door surround, mixer tap, shower head and even the sink plug have all been given the treatment. The big, rectangular mirror above the ‘floating’ washbasin is excellent, as is the generous storage provision. The shower cubicle is good and spacious, with shelves for gel and shampoo.
The washroom’s position at the back of the caravan (and therefore at the back of the bedroom) indicates the VIP 575’s likely use as a de-facto two-berth, unless guests are happy to tiptoe past your bed to use the facilities during the night.
Lighting – 91%
You certainly won’t struggle to see what you’re doing anywhere on board. Each corner of the lounge has its own, multi-directional swan-neck reading lamp; this is backed up by a couple of ceiling-mounted pin lights. Mood lighting peeks out from the uppermost perimeters, as well as from under the windows and from the underside of the kitchen and nearside counters. With just the ambient stuff switched on, it looks great of an evening. The kitchen also features an LED under-locker strip and two powerful downlighters on the built-in extractor.
The bedroom is really nicely illuminated. Each occupant has a swan-neck reader, and there are two flush-fitting lamps (above the window on the offside and above the long mirror). For a softer feel, the undersides of each wardrobe have LED strips that cast a warm glow onto the bedside tables, and ambient lighting runs along above the overhead lockers. A useful floor-level night light can be switched from either side of the bed.
The lighting that surrounds the big mirror in the washroom looks really classy. One switch controls that, plus there are a couple of pin lights and a dedicated shower light.
Verdict – 92%
If you’re in the market for a luxury fixed-bed caravan, this is a beautifully made, beautifully presented offering and an extremely pleasant place to be.
*Correct as of 25 August 2026 for a start date of 23 September 2026. Based on an outfit paid value basis of £39,080 with 6+ years no claims (not protected), with a wheel lock and Thatcham Approved tracker, stored at home, with a £250 excess. Equipment and contents not included. Cover is subject to underwriting. Please visit our website, or call us, for more details or a copy of the Cover wording.
Caravan Cover
Caravan Cover
Switch to us and get Trustpilot 5 Star Excellent rated financial cover for your caravan.
Learn more
Man in high vis stood next to caravan a frame
Caravan towing courses from £184
Choose from either of our caravan towing courses designed to boost your confidence.
Find a course near you
Entrance to caravan storage facility with barrier raised and green railings
Storage facilities from just £1.14 per day
Store your caravan, motorhome, trailer tent or boat on one of our storage compounds across our site network.
The benefits of Caravan Cover
Caravan Cover protects you against financial loss should your caravan and/or its contents be lost, stolen or damaged.
See the benefits
