Awning accessories
Sammy Faircloth
Sammy Faircloth suggests ways to transform your awning into a cosy living space
An awning can act as a useful – and comfortable – extra room
These days awnings are no longer just spaces to kick off muddy boots or dry the dog in after a walk. An awning is increasingly used as an extension of the living area; somewhere to dine, entertain friends, give the children extra room to sleep, or simply relax and take in the view. To make an awning feel homely, comfortable and easy to use, a few well-chosen accessories are needed...
Lighting
The Isabella Travelight flat-pack lampshade
While a single light may be adequate for a short trip, if you intend to read, play games or entertain in the awning, it is worth thinking about a more considered lighting set-up.
First, think about the type of light you need: warm lighting creates a cosy atmosphere, while brighter lighting is better for tasks such as cooking (if you intend to cook in an awning always heed safety advice – such as providing adequate ventilation and keeping heat sources well away from flammable fabrics).
Mains-powered lights can be useful if you have electric hook-up, but rechargeable USB lights are potentially much more flexible and reduce the need for trailing cables. Solar lights help create gentle evening ambience, although they may be less reliable after dull days.
Cable management is important. Avoid creating trip hazards and keep cables away from wet areas – and make sure any mains-powered equipment is suitable for outdoor or awning use.
Lights that clip to poles, hang from the roof or attach magnetically can be particularly practical, as they keep floor space clear.
Mats and carpets
Interlocking floor mats are perfect for hardstanding pitches
A simple, breathable groundsheet or awning mat can make a huge difference, keeping feet, chairs and equipment away from damp ground. (Many campsites stipulate that breathable mats must be used to protect the grass.)
Awning carpets are usually thicker and can make your extra space feel much more like an extra room – some fit specific awning sizes, while others are more general-purpose. The downside is weight: a thicker carpet may feel lovely, but it is also more cumbersome to transport. Look for something that is easy to shake out, quick to dry and practical to clean, especially if you travel with children or dogs or are likely to have muddy walking boots.
Interlocking floor mats are a practical choice for hardstanding pitches, where sharp or uneven stones can be uncomfortable underfoot. They are usually lightweight, fairly inexpensive and easy to source.
Storage
Lightweight outdoor carpets can be a very practical option when storage space and payload are limited
Much of my awning storage dates back to my tent camping days, including a compact folding cupboard. It is a really useful piece of kit for keeping towels, food and other essentials organised.
Hanging storage can also work well as it frees up valuable floor space. However, it is important not to overload it, particularly if your awning has fibreglass poles – too much weight can cause them to bend.
Suction hooks fixed to the side of your caravan or motorhome are another simple but effective option, and are ideal for hanging coats, towels or lightweight accessories.
Ceiling liners
Ceiling or roof liners can help reduce condensation and give the awning a cosier, more finished appearance
Ceiling liners are often overlooked, but they are especially useful if you use your awning early or late in the season, or if you spend long periods sitting in it during the evening. They can help to reduce condensation by creating a barrier between the warm air inside the awning and the colder roof fabric. They can also improve insulation slightly and give the interior a softer, more finished look.
Storm straps
Take care when fitting straps over the awning roof, as they can rub against fabric and cause damage
Storm straps are a sensible accessory for anyone who uses an awning regularly, particularly on coastal, hillside or exposed pitches. They help stabilise the awning and reduce movement in windy conditions.
The key is to use the straps correctly. They should be compatible with your awning and attached to the correct points, rather than thrown over the roof in a way that could damage the fabric. They should be pulled firmly but not aggressively tightly, as over-tensioning can place unnecessary stress on the awning frame or seams. It is also worth checking them periodically, especially after rain or wind, as pegs can loosen and straps may need adjusting.
Final thoughts…
Annexes can be great additional sleeping spaces for children
There is a wide variety of awning accessories out there, so choose carefully.
Think about how you tour and what will genuinely make life easier. For short trips, a mat, lighting and sturdy pegs may be enough, while carpets, liners and storm straps might be worthwhile for longer stays away. The best accessories are practical, easy to carry and help make your awning more comfortable without complicating matters.
About the author
Protect your vehicle
Did you know that you still need to protect your caravan, motorhome or campervan whilst staying on a seasonal pitch?
Get a quote
Club Shop
Exclusive member savings on over 3,000 products from touring essentials to leisure desirables.
Taking care of your outfit
Discover the best ways to take care of your towcar, caravan and motorhome
View all our tips
Advice and training
We have over 115 years of expertise - take our free advice or book a training course with us.
Get started
